Brandon avatar image
Brandon asked
Lynx Power In and Lynx Shunt required for use of 2x UP2500 PylonTech batteries (in paralell)?
I am connecting 2x UP2500 24V Pylontech batteries in parallel for use with the Multi-Plus II 24V/3000VA and was wondering if I need Lynx shunt or Lynx power in to do this. Or is the Pylontech internal BMS capable of monitering all of this and communicating with the Cerbo GX.
Below is the details of the setup I will be running. Please feel free to point out anything else I may be missing with this setup. Thank you in advance!
-2x UP2500 PylonTech 24V batteries
-Victron Multi-Plus II 24V/3000VA
-Victron Smart Solar MPPT 150/100 Tr
-6x 370w Trina solar panels
-Victron Cerbo GX and Touch display
BMSEasySolar All-in-OnePylontechbatterylynx shunt
Jack Peters avatar image
Jack Peters answered ·
The Lynx shunt is not required. The batteries are smart batteries that communicate directly with the Cerbo GX using a VE.Can to CAN-bus BMS type B Cable.
