greg-valet avatar image
greg-valet asked
How to configure Pylontech US5000 with Easysolar 2 ? (SOLVED)
Hi all,
I'am new with victron systems, and I tried to find answers in manuals but I was unsuccessful. I need for my company to test a EasySolar II + US-5000 system for autonomous installation. PV + Inverter + Battery work but battery BMS isn't recognized ? I can't get SoC from Victron VRM ? Any other tips than https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
Thanks,
Aloha, Greg.
BMSPylontechEasySolar All-in-One
kevgermany avatar image
kevgermany answered ·
You need to use the Victron type A cable between the US5000 and the EasySolar, not the Pylontech cable. If you have multiple batteries, the Pylontech cables will work for battery to battery communication.
greg-valet avatar image greg-valet commented ·
Thank you Kevgermany, In fact I tried each cables, the blue and the grey from victron, from CAN.BUS(ES II GX) to CAN (US5000) and nothing changed ?? I added the CAN resistance on ES II GX.
I'm a bit suprised it works to power a vaccum in AC, the battery is charging but in reality the BMS isn't connected, Is it safe ?
greg-valet answered ·
My bad the good cable was delivered in a lost package.. So it works better now !
On the is it safe question...
Firstly you should set the charge parameters in all/any chargers as a safety measure, even though the Pylontechs will override them.
If you try to overcharge, the built in BMS in your batteries will prevent damage.
So yes, safe.
