bobamike avatar image
bobamike asked
IP65 charger: Can't change absorption time to under 1h?!
I have a Canbat 100ah lithium battery and purchased a Victron IP65 charger to charge it. I set up a user defined preset so I could follow the manufacturer's charging specifications. When I try to set the Maximum Absorption Time is the 0-6mins that the manufacturer suggests, the app won't allow me to set anything under an hour? You are able to select any time under an hour but the charger then changes it back to 1hr. The firmware is updated to 3.25. I am doing something wrong or is there a way to set this to under an hour?
Thanks in advance for the assistance!
battery chargingVRMLithium Batteryip65
Nev avatar image
Nev answered ·
