notger avatar image
Wattage logging accuracy of VE.Direct Devices?
I’m operating a small 600Watt (probably upgraded to 1200 soon) offgrid system.
Until now I only use Victron Components…Smart Solar MPPT 100/30, a CCGX and an old Victron 350Watt Inverter, And a no Name DCDC Converter (converting 24 Volt Battery into 12V)
I really Love the CCGX functionality and overview about all Energy usage and gain on the Display and also the VRM-Portal.
So I did some Research here in the community, and found out that the Wattage logging of the Phoenix VE.Direct inverters is really not accurate.
https://community.victronenergy.com/questions/13158/phoenix-241200-inverter-energy-use-watts-reading-h.html
So it actually kind of useless to base Energy-Consumption-Calculations on that Logging then.
How is your personal experience with the new Small Multiplus Chargers/Inverters
https://www.victronenergy.com/inverters-chargers/multi-500-va
….(the are not added to the Demo Library right now, so I do not know what gets logged)
Is the Measurement accurate like with other Multiplus ?
And how is this accuracy ?
Greets and Thanks
Gernot
CCGX Color ControlVRMPhoenix Inverter
Hi @notger
The small Multiplus units (Multi's always have Ve.bus connection) have the same functions and accuracy as the big units.
The ve.direct units indeed have a very rudimentary readout, like this:
Also: consumption doesn't show in the dashboard view if VRM with ve.direct device.
notger avatar image
notger answered ·
Are the "new smaller" Multiplus
actually the same as the the "old" Multiplus-Compact
just in Plastic-Housing instead of Steel-Housing now ?
Cause in the Victron-Connect-App Demo Libary i can just find the Multiplus-Compact for now.
will all shown and logged data be the same ?
They function the same as the Compact units, you can even parallel them or make 3 phase systems.
notger avatar image
notger answered ·
@Daniël Boekel (Victron Energy Staff)
"Also: consumption doesn't show in the dashboard view if VRM with ve.direct device."
Ah, Ok, so you mean the Watt-Cunsumtion of Ve.Direct Inverters will not get added/summed up in the VRM "Consumption" ?
What about the CCGX dies it show up in "AC Loads" actually ?
No they do not show up, if you have a BMV then you can see the DC-load of the unit.
