octafish avatar image
octafish asked
Troubleshooting a GX 4G LTE modem with a GX device.
Hello all,
I would love some advice and some help from the gurus on this site.
I can’t get my GX 4G LTE-A modem to connect to the internet.
I have a sixfab sim card which I tested through the GX by itself, connecting successfully to the VRM.
However after careful installation on my boat, it will not connect anymore.
I just read this documentation note which I suspect is the culprit:
“Note that the GX LTE 4G can only be used if the MFD and GX device are directly connected to each other, without a router.”
From - https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-app.html#UUID-d5fa693e-1c4b-ec20-be20-e0baf8803e6e
Which immediately struck me.
I currently have the 4G modem connected to my Raspberry Pi/GX device which then connects to an ethernet network switch that has (2) simrad/navico MFD’s. The displays share sonar info and other data through the router, along with a connection to the GX.
Is this definitely the problem or is there some workaround or troubleshooting I could try further?
Thanks all…
cerbo gxVRMmarine mfd applte-m
I think you have to rewire to rule this out. But given it worked before installation, looks as if the indirect connection is the issue.
octafish answered ·
I recently tried disconnecting my ethernet switch altogether from the Pi/Venus GX but even after testing different configs I still can’t get it to connect or stay online :(
Here’s some screenshots, hopefully somebody can call out the issue or give me some insight. Also attached a screenshot of the Sixfab portal. I’m currently seeing Claro Twilio 4G (carrier) network.
