jtingram2691 avatar image
jtingram2691 asked
Cerbo GX connected with LTE 4G antenna not connecting to VRM portal
Last week I set up a test bench at our shop's shed, which included a Cerbo GX connected to a Smart Shunt, Multiplus Compact, and LTE 4G antenna. I had been experimenting with the setup and accessing the Cerbo GX via cellular network, however over the weekend I am no longer able to access the system through the VRM portal. I had some connectivity issues previously, but now I am unable to connect at all (even after resetting the whole system).
Is there some setting that needs to be changed in order to get connectivity back?
cerbo gxVRMlte-m
