mjbruen avatar image
mjbruen asked
Cerbo GX x Raymarine MFD - Victron Application not appearing
Hello!
I'm having trouble connecting a CerboGX to a Raymarine Axion MFD. Raymarine MFD and the CerboGX are updated.
I'm doing this on a testbench to make sure it works before installing.
Equipment in use:
  • CerbGX
  • RayNet (F) to RJ45 (M) - 1m
  • 100Ah Lithium Battery
  • SmartShunt (to have a device connected).
The main problem is that the Victron App not appearing on the MFD. I have tested, and read, and tested again, but I have found no solution.
I have seen many people having trouble with this integration.
Can anyone give me some advice here?
cerbo gxVRMVictronConnectmarine mfd appraymarine
@MJBruen
Have you enabled the Cerbo to display on the MFD?
mjbruen avatar image mjbruen Alexandra ♦ commented ·
Is it 13.2.4 GX Device Configuration you are referring to?
I did these settings as the instruction said, seems correct to me.
