Masquelier Pierre avatar image
Masquelier Pierre asked
can IPV4 over IPV6 of the router block the VRM via the LAN from VENUS on EsaySolar 2 GX?
Recently, My FAI updated my router with CGNAT without notification. IVP4 is so emulated over IPV6.
can this be the cause that the "Nanopi VENUS" 's LAN does not connect after the WIFI is cut?
is VRM/Venus support correctly IPV6?
or can Venus LAN be configured by router in IPV6 instead of IPV4 (IPV6 don't use DHCP)?
or Does IPV6 take precedence over DHCP IPV4 in general?
What's append with bad connection in wifi?
Does VRM mean one IPV4 address per LAN? Because just before there was an IPV4 address with wifi?
VRMEasySolar All-in-OneTCP IP Networkingethernetlan ccgx
