Oleksandr avatar image
Oleksandr asked
RS 48/6000 not supported via VE.Direct, not connected via VE.Can
Hello, community!
I have updated RS 48/6000 to v1.11 and Cerbo GX to v2.92 recently. After the updates it appears RS is neither supported via VE.Direct nor can be connected via VE.Can.
With VE.Direct the system (RS + Cerbo) still works, although RS in not shown on Control Panel (the invertor is “off”). With VE.Can the system doesn’t appear to be working at all.
Please advise if the issue can be resolved.
Many thanks,
Alex
Venus OSfirmware updateVE.DirectVE.Caninverter rs
Alexandra avatar image
Alexandra answered ·
@Oleksandr
Is the VE Can connected to the correct port with the Can terminator and is it set to 250kbit/s?
And it is in the manual the ve direct is used for programming and should not be used to connect to the GX.
Oleksandr avatar image Oleksandr commented ·
Thank you @Alexandra, that was exactly the issue. Setting VE.Can to 250kbit/s resolved it. Sorry, for creating unnecessary confusion.
Alexandra avatar image Alexandra ♦ Oleksandr commented ·
@Oleksandr
No worries. Glad it is working.
Many thanks, Alexandra, this is very helpful. I will check later this week and report back if the problem is solved.
Regards,
Alex
Inverter RS Product page.
Inverter RS Online Manual.
Inverter RS Datasheet.
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
VRM: Remote firmware update
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
Updating VE.Bus firmware, using VEFlash (Depreciated)
VE.Direct protocol FAQ
