bathnm avatar image
bathnm asked
VE.Bus BMS, SmartSolar MPPT Ve.Can and Can verses VE.Direct connection
I have a 2 x SmartSolar MPPT VE.Can 150/70 rev2, Smart lithium, MultiPlus, BMS, Cervo, etc, all Victron.
I have not found any clear documentation about the functionality one gets when connecting the SmartSolar MPPT via VE.Can or VE.Direct.
I connected them originally via VE.Can and no screens on the VenusOS would show if the MPPT's where working as a single pair, networked and in sync, or would get BMS Charge Disable signals from the Cerbo.
I have them connected via VE.Direct at the moment, and in the Cerbo there is now a "Networked operation" screen, under each charge controller. However BMS control is still No.
Is there any documentation or guidance that exists about the best protocol to use to connect the controllers and the benefits and features of each.
I really want to know if the BMS Charge Disconnect signal is passed through from VE.Direct to the MPPT's, can they work as a synchronised pair, can they get charge current (non ESS setup) from the Cerbo, etc.
Many Thanks
MPPT SmartSolarLithium BatteryVenus OSVE.DirectVE.Can
