eric-heiberg avatar image
eric-heiberg asked
Maximum SOC dropping by 0,5% every day.
Recently my SOC kept showing less and less (down to 46 % before I partially solved the problem) even though the battery showed 28,2 volts (24 volt lithium Ion battery -Easysolar 3kVA).
I set the charging values on the multiplus lower than the MPPT (since I dont have a bluetooth dongle yet I cant adjust the MPPT charging parameters) after reading about this here on the forum.
The SOC then bounced up to 100% -but the maximum SOC % is slowly going down again by a rate of 0,5% per day:
Now the SOC is showing 97% as todays highest although the battery voltage is the same (28,2 volt).
Any tips on how to solve this?
Eric
Lithium BatteryEasySolar All-in-OneSOCbatteryoffgrid
moonlightrider avatar image
moonlightrider answered ·
I remember I had a similar problem with my little (UPS) setup here
I related this to voltage adjustment to meet battery temperature (sensor), that may cause small ghost loads from time to time... anyway that's what I think, never ever Victron staff gave me a explanation.
The only workaround I came up was correcting (via automatic script in Venus OS, running on Rpi) SOC every day to 100% if system state is in 'Storage'
That script uses dbus to correct SOC on the Multiplus...
boekel avatar image
boekel answered ·
What is the source of this SOC value? (multi, BMV, BMS, ??)
You'll need to tweak the settings of this battery monitor to get the reading correct.
eric-heiberg avatar image eric-heiberg commented ·
Multiplus in the Easysolar 3kva is the source -adjusting the charge settings lower partially works.....
eric-heiberg answered ·
Thank you for your answer :-) What do you mean by tweak?
Eric
boekel avatar image boekel ♦ commented ·
change the settings until it works correctly.
What settings do you have now?
increasing the 'charge efficiency' setting is probably the thing you need.
EasySolar 1600 product page
EasySolar-II GX 3000 & 5000 product page
Victron Offgrid page
Battery Compatibility
