saintgtr34 avatar image
saintgtr34 asked
Data path of a USB stick on the Rasperry pi with Venus Os
Hello everyone
I have a Raspberry pi with Venus OS large and would like to write data to a USB stick plugged into the Pi using Node Red. Unfortunately I couldn't find out what the path of the USB stick is, and all Linux commands don't work to find it out. can someone help me?
Venus OSRaspberry PiNode-REDstorage
bathnm avatar image
bathnm answered ·
@saintgtr34 If you have shell access via ssh you should find the Linux commands do work.
It will be mounted under /run/media/.... as an example /run/media/sda1
saintgtr34 answered ·
It was exactly /run/media/sda1
Many thanks, that took my quiet a bit time.
With the new update I got a new problem. I swapped the Pi for an Octo GX with FW 2.90 and access to the USB stick is newly denied. Then I found this on the official site:
Since Venus OS 2.90 and on wards, Node-RED no longer runs as user root, but as user nodered. This means that the Node-RED flows are only allowed to access files and directories that are owned by the nodered user. These files typically start below /data/home/nodered/. So modifying the storage location to something like /data/home/nodered/storage.txt ought to work.
Is there still the possibility to write data to the USB stick? And then how?
