svent avatar image
svent asked
Venus OS on RASPI 3B+ - Q1: temperature, Q2: separate Node Red
Hey there,
currently I prepare my eco-system to add a Raspi with Venus OS.
That´s the plan in simple words....now the bit more complex :-)
First the system:
- SmartSolar MPPT 100/30
- BMV 712
- LifePO4 battrery with JK BMS
Q1: Temperature
As it is a stand-alone system in an allotment garden, the Raspi 3B+(with a 7" touch) will be placed inside the garden shed.
In the shed the ambient temp can rise up to 35°C in the summer.
I will place the well-known heatsinks on the Raspi chips.
Is that sufficient or do I need a small fan vor active colling of the system.
Can Vanus OS control a relay/PWM to start the dan dependent on the CPU temp?
I already have a smart home system in the garden with a Node Red.
Can I simply install the "small" Venus OS and access the Venus via the existing NodeRed instance?
Thanks in advance and happy energy harvesting
S.
Venus OSRaspberry PiNode-REDTemperature Sensor
