mknoxc avatar image
mknoxc asked
New batteries installed: GX Error #48 DVCC with incompatible firmware: Warning
Below is my current installation. As you can see I‘m stuck on firmware v413. Any ideas how I can remove the GX Error? What firmware version should I be running and how can I update to that version?
Easysolar:
MultiPlus 48/3000/35-50
Note - Firmware installed v413, latest v496, not updatable (1342)
BYD LV Flex Lite x 4
Note - BMU v1.22, BMS v1.13
cerbo gxfirmware updateEasySolar All-in-OneDVCCBYD
JohnC avatar image
JohnC answered ·
Hi @mknoxc
You'll need to buy (or borrow) one of these.. https://www.victronenergy.com/accessories/interface-mk3-usb
And have a Win laptop with VE.Flash (I think) loaded. Your CCGX is too early to use the remote firmware updates (as is my own).
To plug into the VE.Bus port of the Multi you'll need to remove the lower front cover of the Easy. Pull the VE.Bus cable that goes to the CCGX when you have the MK3 plugged in for the update.
There's links in the above one which should explain how to do it, but come back if you're unsure..
mknoxc avatar image
mknoxc answered ·
Updated in accordance with above recommendation. Problem solved. Many thanks.
