Marcus avatar image
Multiplus 12/3000/120-16 and CerboGX with LiFePO4
On my boat I am upgrading the electrical system from AGM batteries, 16 year old charger to VICTRON with LiFePO4.
For this I have already installed a CerboGX with MPPT for Solar and this winter I am going to replace the old charger and the old AGM batteries with LiFePO4 2x 280aH 12V batteries as well as the Multiplus 12/3000/120-16.
In the description of the Multiplus I cannot find how to connect the Cerbo with the Multiplus, as I only find two RJ45 connections for a Remote, which I do not plan to buy.
Is this even possible?
MultiPlus Quattro Inverter Chargercerbo gxLithium Battery
JohnC avatar image
JohnC answered ·
Hi @ObiOne
Of course it's possible. Those RJ45's in the Multi are VE.Bus, not to be confused with Ethernet or Can. Maybe you haven't found the manual yet?.. https://www.victronenergy.com/media/pg/Cerbo_GX/en/installation.html
I've always said that Victron comms are somewhat challenging, but you get that with the best. Great choice, you'll love it once you get past the minor detail.. :)
I found that, I was just puzzled, because the manual of the Multiplus does only talk about Remotes, but not about Cerbo or a network functionality. But perfect, then I planned everything correct. :-D
But all the cables are the same, right?
VE.BUS, CAN.BUS, Ethernet -> all RJ45/CAT6 cables?
@ObiOne
Yes, all just straight too, not crossover or anything exotic. But use quality ones..
