chris-zell avatar image
chris-zell asked
Incorrect energy display in VRM portal - MultiPlus II with EM24
I currently have the following phenomenon:
In the VRM Portal the displayed sum value of the energy meter jumps between a few watts, the current power of a phase and the correct total power (see image 1).
Via the remote console, the correct value is always displayed (in the system schema as well as on the overview page).
System setup:
1 MultiPlus II GX FW: 2.72
Connection mains parallel to AC1
Energy meter EM24 Ethernet FW1.6.48 - use phase balancing 3P.n
- AC coupled PV system with power feed-in
- ESS with external meter
1) example Remote Display & VRM Dashboard with different energy sum
2) example VRM Dashboard correct sum energy
3) example VRM energy meter log
Multiplus-IIVRMEnergy Meterem24
