coyoteandlizard avatar image
coyoteandlizard asked
Total network power on bmv app
I wish the bmv-712 would show total network power/ total PV power as well as net power. Maybe even add a line for each charge controller included in the network. It would be significantly better to have a single source for all of this information. The ability to rename the components would also improve the usefulness of the app. That way I could name a charge controller something like "South Array" and be able to compare differences easily.
MPPT ControllersBMV Battery MonitorVictronConnectSmartShuntVE.Smart Network
bathnm avatar image
bathnm answered ·
What you are describing is what the VenusOS is for. You can either purchase as a complete unit with display, such as the Cerbo GX or use a Raspberry Pi and just run the software. If you go down the Raspberry PI route then you also need a lid of VE.Direct to USB converters
