jcf avatar image
jcf asked
control victron mppt with linux or windows
Hello ,
I have a project should to start soon and I am looking for a specific MPPT .
MPPT
battery 10pack of 14s
Windows or linux laptop .
What I want to achieve is getting the data from the mppt and control the mppt by script .
10 battery will be connected the laptop they will be connected in parallel but I will connect a diode between them to no discharge it and maybe only one battery will accept the discharge if the mppt require this .
I want to controll the mppt because the battery will not have the same voltage so maybe after 5 hours 6 battery will be full and 4 still to be charged .If it's sunny day ,I don't want them to be charged at 20A each or more .
so with the BMS the laptop will now how many battery left need to be charged and can control the mppt to reduce the power to save my battery life .
simple way to say that Is I hope windows or linux can control the mppt .
If it's working with only some mppt please let me know .
thank you
MPPT ControllersVictronConnectlinux
wkirby avatar image
wkirby answered ·
I think to get you started you should read the documentation related to the communications protocol, VE.Direct, VE.DirectHEX
Here is a link, scroll down to the bottom of the page:
https://www.victronenergy.com/support-and-downloads/technical-information
