natdak avatar image
natdak asked
Pheonix Inverter 24/3000
Hello, Im having problems with my Pheonix 24/3000 inverter. After buying it second hand, I have never got it to work. First it simply did nothing when i flicked the switch, now the green light ontop is flashing but there is still no output power.
Both occasions I checked the voltage at the inverter terminals and beyond the fuse. It showed 25.5v when the power switch was off and when it was on. So I dont think there is a bad connection. It is however quite cold here in Sweden and it has been in a room the has been below 0 degrees celcius on both attemps. The first attempt was maybe at -4c when the inverter showed no light and -10c on the attempt when the light started flashing.
Could it just be the cold?
The batteries are gel batteries that stay topped up so I think they can handle the cold.
I had a hope that doing a software update might make it work again but VictronConnect cannot find the device when plugged in. It is connected to the laptop with an RJ45 cable through a USB adapter.
Could it be the adapter that doesnt allow the connection?
There are 2 RJ45 ports in the inverter. Ive tried both of them.
Thanks folks! Any advice is much appreciated.
Nathan
MPPT ControllersMultiPlus Quattro Inverter ChargerPhoenix InverterVictronConnectfirmware update
The RJ45 is not ethernet it is VE.bus with a special protocol. You will need a MK2 or MK3 Interface to connect to it.
natdak avatar image
natdak answered ·
Thanks Matthias, I will get on that
natdak avatar image
natdak answered ·
Do you think that it is the software update that is needed to get it working?
