brandon avatar image
brandon asked
Multiplus compact displays "low battery" and won't start
I have a 200ah 12v system with a multiplus compact inverter. Recently, my inverter shut off and displays "low battery". I was changing cables (I shut everything off and disconnected the battery) and I think it might be the probable cause.
Problem: it hasn't started back up yet, despite the soc being 100% and voltage not falling below 12.9v. I've given it days and "low battery" still displays on the controller.
Main question: Can I fix the issue without having the MK3 or is this something that I need to fire it back up?
Phoenix Inverterlow battery warningmultiplus compact
macca61 avatar image
macca61 answered ·
silly question but do you have a fuse between it and the battery also i have had a faulty battery isolator although it gave a good solid clunk when switching it didnt actually connect
brandon avatar image brandon commented ·
Hi. Yes, I have a 200amp fuse between.
When I turn the van on, I can see that the battery isolate is engaging through the app. Do you think the isolator has something to do with the inverter not turning on?
Did you or someone else ever changed some settings in the Multi?
The default "low voltage restart" setting is 10.9V so at 12.9V it should start up.
Hi Mathias. Thank you. Yes, a few weeks back I had a technician program it, but he set the low voltage setting to 11.9v. I still never get below that. I'm sure it did when I changed the wires, but my main concern is despite it being higher now, it's not turning back on.
seb71 avatar image
seb71 answered ·
Where are you measuring those 12.9V? At the battery terminals? If yes, measure at the inverter terminals, too, just to check.
Phoenix Inverter product page
Phoenix Inverter Smart product page
