geert avatar image
geert asked
how to get inverter phoenix 12/1200 only restart when battery is full
When battery is low, the inverter shuts down to protect the battery. It restarts when battery is recharged, according to the "low battery restart and alarm". This means that the inverter already restarts when this low battery alarm level is reached.
I would like to wait for the restart to happen only when my batteries are more or less fully loaded. I can adjust the "low battery restart and alarm" level to a higher voltage, but in that case the inverter always will give the low battery alarm! A part from this alarm, and the blinking red led, I suppose everything will work normally.
Is there a way to avoid this - in that case - useless alarm?
Thanks.
Phoenix Inverterlow battery warning
kevgermany avatar image
kevgermany answered ·
I don't think it's possible. Might be a good future enhancement though.
I've been told it can be done with the relay in a BMV and using that to switch via the remote on off on the Phoenix.
mattc avatar image
mattc answered ·
I have just bought a Phoenix Inverter and thought it had this function.
It would be really good if : Low Voltage Shut down
and : Battery voltage Re-start
Could be two seperate settings.
I really don't want my inverter to switch back on when the battery is still low!
Phoenix Inverter product page
Phoenix Inverter Smart product page
