hry avatar image
hry asked
Recommended low voltage shutdown for AGM batteries?
Hello all!
I have 3x 280Ah 12V batteries in parallel running into a Phoenix 12/800.
Any recommendations on a good setting for the low voltage shutdown?
I have read variously around the internet that lower than 11.5 – 12v is already too deep a DOD to maintain the batteries for a reasonable life. Oddly, the default setting for shutdown on the Phoenix is 9.6V. Isn't that way too low? According to my (dodgy) sources, the battery should still be putting out ~10V at effectively 100% DOD.
I have contacted the manufacturer for discharge curves / data but you know. General recs are most welcome.
Thanks
H
Phoenix Inverterlow battery warning
snoobler avatar image
snoobler answered ·
Unfortunately, voltage to state of charge relationships only apply when AGM batteries have been completely dormant for several hours, i.e., just sitting there - no charge or discharge.
It's difficult to specify an arbitrary voltage because voltage drops under load.
Your 280Ah (840Ah) batteries are likely rated at a 20 hour discharge, i.e., 840Ah/20h = 42A. Anything above this means you have less than 840Ah.
Assuming you're pulling a 800W load, that's a 800W/12V = 67A load. The moment you unload it, the voltage will rebound to a higher level more indicative of SoC than when loaded. If your battery is at ~60% SoC, and you apply a max load do it, do you want it to shut off because you've specified too high a votlage cut off? Probably not.
The best solution is to get a BMV or smart shunt and track the true SoC. Get it down to 50% and hit it with a max load. After a few minutes, note the battery voltage and then set your cut-off to something a little below that.
Nick avatar image Nick commented ·
What a fantastic insight, learnt something new thanks to your reply about voltage vs load.
Phoenix Inverter product page
Phoenix Inverter Smart product page
