miya avatar image
miya asked
VRM not displaying BMS Cell Data
Hi All
I have 3 Victron Lithium batteries, BMS, Cerbo, BMV712 - all connected and working perfectly.
Set up VRM and every, again, working perfectly, I am getting all the data coming through.
However, there are 2 widgets, showing no data - they relate the BMS.
See attached picture - any thoughts what the BMS is not sharing this with VRM ?
Thanks
Tim
cerbo gxVRMLithium BatteryBMS
What BMS do you have? No Victron BMS provide that data.
miya avatar image miya commented ·
Hi Matthias
It is the Victron VE Bus BMS - https://www.victronenergy.com/battery-management-systems/ve-bus-bms.
Do you know if the BMS should show in the Device List on the VRM ?
Thanks
Tim
bathnm avatar image bathnm miya commented ·
No it does not. You can also only get the cell details from BlueTooth / VictronConnect.
The three wire interface between the batteries and BMS only carries a charge disconnect and load disconnect signal.
miya avatar image miya bathnm commented ·
Many thanks Bathnm
Ingo avatar image
Ingo answered ·
I think it's BMS dependent. The VRM portal facility is there but if your BMS doesn't publish it then it will stay empty. Here is Freedomwon that does publish the data - no idea why it's intermittent on the one but still, it's there.
