Multiplus is a Ve.Bus device and can't register temperatures measured by your ve.smart network. Presumably you're using the standard temperature sensor device that comes with a multiplus? That could just be measurement error between different sensors.
As for the smart lithium - its internal temperature measurements would always be different to external probes.
26 People are following this question.
