warwick avatar image
Why is ASS030520410 VE.Direct to VE.Can interface so expensive?!
My eyes nearly popped out of my head.
I was looking for solutions to connecting more than one MPPT to a MultiPlus II GX and thought, "Could I use a VE.Can port with a VE.Direct to VE.Can adapter?".
Sure enough, there is such a thing "VE.Direct to VE.Can interface" (ASS030520410) but it is about the same price as the MPPT I want to connect about 300EUR.
Now, I have since learned that you cannot use VE.Can on the MultiPlus II GX for MPPTs but I am still interested in why the VE.Direct to VE.Can interface is so expensive?
VE.Directvictron productsVE.Can
Vance Mitchell avatar image
Vance Mitchell answered ·
Unsure on pricing, possibly due to low demand causing them to be individually built as required.
To connect more MPPT’s you should be able to use a USB hub and a USB to be.direct cable.
Exactly, the reason is that they are in very low numbers, and its an old (expensive!) hardware design.
And deprecated, in favour of the NMEA-2000 out feature in the GX Devices. Please don't use this old adapter for old products.
https://www.victronenergy.com/live/ccgx:start#marine_mfd_integration_by_nmea_2000
ps. I see now that you were not looking to translate the data of the MPPT to N2K or VE.Can - which is what my above suggestion is about.
To connect more VE.Direct MPPTs to a GX device than there are physical ports, please see the manual:
https://www.victronenergy.com/live/ccgx:start#connecting_victron_products
section "Connecting more than two devices to your CCGX using VE.Direct ".
warwick avatar image warwick mvader (Victron Energy) ♦♦ ·
Yup, see my other post about that. I've returned the MP2 GXes for this batch of installs and replaced them with MP2's and Cerbo's.
