chad50 avatar image
chad50 asked
2 Ve.Can MPPTs 1 Ve.Direct
I have a client with a 150/85 Ve.Can MPPT and 1260w of panels but he wants to add 840w more. Both of which charge the same battery bank. The current 150/85 is connected to a Color Control GX via a Ve.Direct cable. If I add another Ve.Can MPPT and use a RJ45 to connect them in parallel will the Ve.Direct to the GX display the information for both MPPTs?
I know that a RJ45 would of done this to the GX per the manual, but I can't find anywhere if the Ve.Direct will work the same.
Or should I just use the Smart Networking to put the MPPTs in parallel? And if I do that will the Ve.Direct send the info to the GX for both controllers?
The two MPPTs will be on different arrays and have thier own wires. It's just a pain to run another Ve.Direct or RJ45 to the GX, plus it will save the customer on labor cost.
MPPT ControllersVE.DirectVE.Can
wkirby avatar image
wkirby answered ·
If you decide to connect the controllers with VE.Can, then you need to continue the chain to the GX device (don't forget the terminators on the end devices :) ). The MPPT will not convert from VE.Can to VE.Direct.
The other option of course is to connect the other MPPT with VE.Direct also.
Either way, you'll need to run a cable.
Hannes Swart avatar image Hannes Swart commented ·
I would like to know if I have 2 250/100 MPPT's each connected to my CCGX via VE.Direct do I need to put them on the Direct Smart Network or will the CCGX control both?
wkirby avatar image wkirby ♦♦ Hannes Swart commented ·
Just connect the VE.Direct cables to the CCGX.
Make sure there is no VE.Smart Networking between the MPPTs.
Hannes Swart avatar image Hannes Swart Hannes Swart commented ·
Another question sorry, which would be best 2 VE.direct cables to the CCGX or the 2 MPPTs daisy chained via VE.CAN?
MPPT Product Page
MPPT Error codes
VE.Direct protocol FAQ
