duffer41 avatar image
duffer41 asked
SeeLevel II Cerbo GX Connection
I reached out to Garnet to understand which kit I would need to utilize the NMEA2k capabilities of the Cerbo GX. They told me to look at this version: 709-N2K NLP and they would sell it to me directly. I want the Cerbo GX/Touch 50 to be able to monitor the tank levels using this system. I want fresh, black, grey and propane monitored. How does this need to be setup so I can use the Cerbo GX/Touch 50 to display the information vs the display that Garnet has that comes with the kit?
cerbo gxgx devicetank monitorNMEA 2000 - N2K
powerace avatar image
powerace answered ยท
I think most of your answers can be found here:
https://github.com/kwindrem/SeeLevel-N2K-Victron-VenusOS
Unfortunately i have the non-N2K version so i can't confirm if it works.
Goodluck!
4 comments
Kevin Windrem avatar image Kevin Windrem commented ยท
I have rewritten the TankRepeater. It is now here:
https://github.com/kwindrem/TankRepeater
1 Like 1 ยท
aswellian avatar image aswellian Kevin Windrem commented ยท
Curious, does the Cerbo run VenusOS? Venus and VenusOS are referred to in your repository, want to confirm before ordering the 709-N2K NLP from Garnet...
1 Like 1 ยท
Kevin Windrem avatar image Kevin Windrem aswellian commented ยท
Yes, Cerbo, CCGX, VenusGX, OctoGX, CANvuGX, MaxiGX and Raspberry Pi all run "Venus OS". TankRepeater will work on any of them. EasySolar appears to use a CCGX. If so, TankRepeater should work.
I'm not sure about the MultiPlus-II GX. It has a bulit-in Venus device running on a Raspberry Nano PI. It does not have a VE.Can port so you'd need to add a USB CANbus interface. Processing power may also be an issue.
1 Like 1 ยท
Excellent, thanks for the info and your efforts. Will give it a go.
1 Like 1 ยท
