devodave avatar image
devodave asked
Tank 140 on CerboGX - Device instance NMEA2000 incorrect
My Raymarine MFD will not be able to handle a tank with a device instance greater than 5. My CerboGX currently gives my first tank on the Tank 140 a device instance as 10 on NMEA2000, and the second tank as 11. (I have an Actisense NGT-1)
Is there a way to amend these instance values to something Raymarine can understand?
cerbo gxtank monitorNMEA 2000 - N2K
Stefanie avatar image
Stefanie answered ·
Hi @DevoDave,
I also have a GX Tank 140 but not yet installed on my boat network with a Raymarine Axiom+. It should be possible to change the device instance in the Cerbo GX menu under Settings/Services/VE.Can-Port/Devices/ assuming the GX Tank 140 shows up there. You must ensure that no other tank sensor is using the same device instance.
See also: https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-nmea2000.html
and: https://www.victronenergy.com/live/ve.can:changing_nmea2000_instances
devodave answered ·
Cheers for that. I edited the device instance on that setting back to 0 and 1, however they still don't appear on the Raymarine Axiom.
