nic-sama avatar image
nic-sama asked
Lynx Shunt 1000 with Lynx Distributor 1000
Hi
I've recently design a setup with 4 x 12V 200A Smart LiFePO4s in parallel connected directly to the Lynx Shunt 1000. The Lynx shunt is then coupled with a Lynx DC Distributor 1000 on its RHS. Connected to the Lynx DC Distributor is the Victron 12V 5kVA Quattro Inverter and DC loads.
Is it ok to connect the batteries directly to the Lynx Shunt 1000 and the fuse within the shunt can be used as circuit protection for the batteries?
Thanks
Nic
Lithium Batteryfuseslynx shunt
Battery Compatibility
