Aahil Crowther avatar image
Aahil Crowther asked
How to calculate LFP battery cycle?
Hi to all victron community.
I read lots of different calculation method to count exactly one cycle of a LFP battery. What is the right one for Victorn's LFP? If I continuously re-charge them for example from 30% to 40%, does it also count as +1 ?
Thanks for your suuport
Have nice day
battery chargingLithium Battery
ben avatar image
ben answered ·
Well, that’s really up to you. 1,000 small cycles in the middle of the capacity cause way less degradation than 1,000 cycles from 100% to 0% and back.
Sometimes you will see long term tests run from something like 100% down to 20% or to 50%. Those are common cycling ranges since they approximately fairly heavy use in real life.
What do you want to use the cycle count for?
Battery Compatibility
