On the recent Blog post, Jono shows the BMS 12/200 with a 200amp fuse across AB. Victron spec sheets indicate 100amp fuse maximum. I do not have enough info on how or why this is OK @Jono (Victron Energy Staff)
On the AB side the maximal current is 80A (which means the maximal fuse to put in there is 100A). Putting a larger one on that side will not result in extra charge current.
So how does this work then? https://www.victronenergy.com/blog/2019/10/07/careful-alternator-charging-lithium/ he uses a 200amp fuse in the video https://youtu.be/ZyIJRjJtCR0.
I think the starter battery is making up the amperage over 80A. The BMS 12/200 can pull from the starter battery if its voltage is over 13V. This explains why Jono's charge time is longer with the BMS.
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
11 People are following this question.
