daveybdublin avatar image
daveybdublin asked
Smart BMS Cl 12/100 Multiplus Compatibility
Hi there
I note in the manual for the Smart BMS Cl 12/100 that the Multiplus 3kva must be of 'recent type' with auxillary inputs. I bought my Multiplus 12/3000/120 about 6 months ago. Can anyone tell me if this version is compatible, picture below of the inputs on my unit.
Thanks
MultiPlus Quattro Inverter ChargerBMSve.bus bms
tozz avatar image
tozz answered ·
The manual states: "Application example with a 3kVA Multi of a recent type that has auxiliary inputs". Judging from your photo, you have 2 aux inputs. So even while your unit seems to be from 2017, with hardware revision 1 it looks 'new enough'.
The serial number starts with HQ2045 so that unit is around 6 months old. ;)
tozz avatar image
tozz answered ·
Also, when I lookup the manual for the MultiPlus, the connection overview in the latest manual is identical to your photo. So it looks like you are good to go!
daveybdublin avatar image daveybdublin commented ·
Cheers Tozz
