evofxdwg avatar image
evofxdwg asked
BMV 712: How many relays and physical connection?
I can't find a picture, wiring diagram, or list of relay physical connections to the BMV-712 Smart in any of the posted Victron documentation.
But the manual defines all of these relay functions: "alarm relay", "low voltage relay", "SOC relay", "high voltage relay", "low starter voltage relay", "high starter voltage relay", "high temperature relay", "mid voltage relay".
In googling around, I found what claims to be a picture of the back of the BMV-712 with only two wire connection that might be a single relay interface. I don't know if that picture is accurate.
Are there multiple relays for user external connection or one? If one, are all those functions mentioned for setup using the same relay, implying I need to use the USB data connection to determine which function toggled the (single relay)?
I need this information to design my system.
BMV Battery MonitorVEConfigure 3wiringRelaywiring diagram
klim8skeptic avatar image
klim8skeptic answered ·
"I need this information to design my system. "
The BMV has one relay. You get to configure it (via software) for desired use/function.
