kaz avatar image
kaz asked
Wiring a Victron Battery monitor 702 - another question
Hi All
Thanks to those of you who responded to me regarding my previous post. Unfortunately I had posted an incorrect diagram - that caused some confusion - I have reposted the correct diagram here. Apologies I am not even an amature electrician!
Questions:
1) I assume I can still attach all black wires from house to shunt battery only
2) Then all black from start battery to Loads and Chargers
3) then included red wires to shunt/red terminals of batteries as indicated
4) confused through about black wire that goes between black house and black start (in diagram) - feels like that would circumvent shunt if connected to both Battery Only and Loads and Chargers as per above?
5) will switching system still work?
6) I have a battery voltage meter for both batteries - might it be an option to just put Victron on House? If I did - do I leave the black cable between battery on shunt and black on start? Again - feels wrong.
7) will charging system still work - from engine alternator and 20A charger?
Thanks all - really appreciate the support!!!
BMV Battery Monitorwiring
michelg avatar image
michelg answered ·
Hi Kaz, I will suggest that you use a bus bar in order to attach the cables, Much easier to do than having all of them connected to the shunt .
Michel
kaz avatar image kaz commented ·
Thanks Michel for your answer - appreciate it.
kaz
