Diriye Amey avatar image
Diriye Amey asked
SOC on Cerbo GX and VRM
Good morning,
I wanted to know why the SOC is only calculated on the A consumption measured by the smart shunt, and is not taken into account that the multiplus keeps the battery in float mode, at 13.5 volts.
From the diagram you can see that the soc keeps dropping even though the battery is kept at 13.5 volts, now in the cerbo I have selected the battery meter from the multiplus, now the percentage has stopped and no longer drops.
Attached is the diagram of how I have connected the devices.
do you have any explanation on this?
Thank you
This is after i selected the multiplus as battery meter on VRM
cerbo gxVRMVictronConnectSOC
Your diagram is incorrect.
The SmartShunt has to be connected to the battery, then all loads and charging sources are connected to the system side of the shunt.
