james-digby avatar image
james-digby asked
Blue Smart Charger
Hi Hive mind,
I have a DC system - Venus, Smart Shunt, Solar Controllers. Winter is coming and solar isn't quite cutting it, I have a Blue Smart Charger 15amp that I am using to keep my batteries nicely topped up and connected directly to my batteries.
I am wanting to know:
A - how much power I am actually taking from the grid.
B - what do I need to add to make sure VRM is reporting the correct info.
I know adding a Multiplus or similar will report all this, but it seems a little overkill as I have nothing that uses 230V. I have also seen the Phoenix Smart chargers that Have a VE.Direct port built in, but they seem a little overkill as well seen as though I am only using a charge current of 7.5 amps
1. Is it better to use a AC energy meter or a DC smart shunt in energy meter mode
2. If I went down the Ac energy meter path, would it display on Venus as AC IN and my VRM stats show up correctly.
thoughts, comments, suggestions, solutions all appriciated
James
VRMSmartShuntEnergy Meterdc system
