michaeli avatar image
michaeli asked
Smartshunt to monitor solar panels
Ok crazy question. Can I use the smartshunt in dc energy mode in-line with my solar input to measure my solar on the high voltage string? 250vdc? I see that it seems to have an option that leads me to think that this may be an intended feature, but what are the limits of the shunt? I mean clearly it can handle the 64vdc batteries I have, but what is the MAX VOLTAGE it can handle on its VBATT+ input? I can’t seems find this info anywhere.
The reason I want to do this is so that that I can relay the info from my solar array into the Vrm as solar power in. I run two all in one units so I can’t put the smartshunt in-line with the output as it is internal.
Ideas? Thanks in advance.
VRMSmartShuntEnergy Metervrm advanced
wkirby avatar image
wkirby answered ·
The input Voltage range is highlighted in the datasheet, the first field of the table:1650955270118.png
Datasheet here:
https://www.victronenergy.com/upload/documents/Datasheet-SmartShunt-EN.pdf
michaeli answered ·
I want sure if that carried over to dc energy mode or not. Can be confirmed?
Supply voltage = "Battery voltage"
There is also an high voltage BMV but i think it can't be used as a DC meter.
https://www.victronenergy.com/battery-monitors/bmv-700h
michaeli avatar image michaeli Matthias Lange - DE ♦ commented ·
I wonder how I would find out if it can be used as an energy meter. I would like to use two of them to monitor two solar arrays, around 300v
klim8skeptic avatar image klim8skeptic ♦ michaeli commented ·
VRM dashboard would combine 2 mppts, but might be worth a look?
pau1phi11ips avatar image
pau1phi11ips answered ·
What communication modes are available on the all in one units? You might be able to get the stats via RS485 and and write it to a PV inverter on the Dbus.
