Paul avatar image
VE. Bus BMS with Skylla ip44 via Venus GX
If I connect a VE. Bus BMS (connected to Victron Smart LiFePO4) and a Skylla IP44 to a Venus GX, will the BMS be able to control (disconnect/connect) the charger without additional devices (remote disconnect)? Or, must I use the BMS charge disconnect output?
Venus GX - VGXBMSchargingLithium battery Smartskylla-i
Hi, Paul.
I have exactly the same components and would also like to know if it is possible. Please let me know if it works for you - I have not installed mine yet as I am still researching the possibilities.
How will you connect the VE.Bus BMS to the Venus GX? Is it possible to use the Multiplus/Quattro connection for this? The manuals are not very clear on this.
I chose the Skylla-IP44 charger for its variable voltage input. This way I can plug my boat into shore power anywhere in the world. On the charging side I also have solar panels and alternators that need to be controlled.
Philip
Hi @SeekingSanity
Yes this should work (as always test these functions)
Share
