corrie-jnr avatar image
corrie-jnr asked
Solar Panel not showing on the VRM Dashboard after changing wifi network
Good day
We recently updated our router and changed the network name, we re-connected the vrm box to the correct wifi and inserted the password. The problem is that I can no longer see the solar input panel that was there previously?
The battery still shows that it is charging with what I can assume is the solar, as it is not the main. The only problem is that the info panel showing solar no longer displays , it also doesn't mention or show the yellow solar graphs anymore.
VRMSolar Panelsolardashboard display
nickdb avatar image
nickdb answered ·
Did you restart the PV inverter and/or check it had received new IP details as well?
