mysik avatar image
mysik asked
VRM stats, Solar "To battery" graph
Just checked my stats in VRM portal and on the dashboard in the "Solar" stats it is not showing energy going to the battery. My system is set up as bellow:
My Multiplus-II is using excessive solar power to charge batteries and that is working correctly, but in the stats everything has been counted as "Direct use" :
just a small 0.02kWh has been shown as "To battery" which is wrong. At the time when I took the screen shot, the battery has been charged from 84% to 100% and at the moment excessive solar power is going to the grid which looks like it's been calculated correctly. Any idea why is it not counting "To Battery" energy correctly???
VRMbatterysolar
Hi @Mysik
can you describe your system a bit better?
-on/off grid
-what components
-ESS? if so what mode
-what (kind of) batteries
-etc.
mysik avatar image
mysik answered ·
The problem has been solved and it is all working fine now. After Multiplus power cycle the portal started logging as expected.
