Accidentally hit the "S" key while looking at my VRM portal and it pulled up a nice looking and super simple UI element that looks like this...
Are there other "secret" or non-standard UI choices to have pulled up?
@Ghostrider That is the screensaver you are seeing, you can let the UI auto switch to it by setting the screen saver timeout in your profile settings.
The shortcut 's' is to directly bypass the timeout and show the screensaver immediately. It's the only "secret" there is
25 People are following this question.
