fabulous-gonzo avatar image
fabulous-gonzo asked
Deye Sun G3 micro inverter integration
Hi folks,
based on the great work of @vikt0rm and others. I was able to integrate my Deye Sun G3 micro inverter into Venus OS.
No additional meter is needed, the data comes directly from the micro inverter and is read out via Modbus.
Known limitation is: The inverter does not provide real-time data but updates its registers only every 5 minutes. If this is enough for you, this is a good solution.
The service also takes care of the reset of the Daly Production if the inverter is not connected to the Solarman cloud.
The script is published on Github:
https://github.com/s10l/dbus-deye-sun-g3-pvinverter
Venus OSEnergy MeterAC PV Couplingmultiple inverterssystem integration
