wojciech-kasperek avatar image
wojciech-kasperek asked
energymeter from mqtt topics
i am trying to use my energy meter readings in venus os but this is zamel MEW-01 which has no integration with venus os.
Is it possible to build a virtual energy meter on venus os using mqtt themes subscribed by mew-01?
So far i have cloned a few mqtt themes from my home mqtt broker by adding to mosquito.conf:
connection bridge-abcd
address 192.168.5.3:1883
topic supla/# in
topic homeassistant/sensor/supla/# in
#topic supla/# out
#topic homeassistant/sensor/supla/# out
remote_username LOGIN
remote_password PASSWORD
Has anyone done it?
Venus OSEnergy MeterMQTTmodifications
matt1309 avatar image
matt1309 answered ·
Hi @Wojciech Kasperek
There are a few community made custom drivers that have done similar with different energy meters. One of the most popular at the moment is shelly energy meter custom driver.
GitHub - fabian-lauer/dbus-shelly-3em-smartmeter: Integrate Shelly 3EM smart meter into Victron Energies Venus OS
You may be able to use the above link as a starting point for tweaking the data to come from your energy meter. I'm not familiar with the brand you mention however if it has an API or then you should be able to just tweak the python code to get the relevant information from your meters api rather than shelly
(the functions call _getShellyStatusUrl and _getShellyData are the ones you'd need to start with tweaking from having a quick scan, you may also need to add some info to meter_data or remove dbusservice lines for info you dont have from your meter).
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
Energy Meter Selection Guide
Victron MQTT readme
Experiments, Modifications and Adaptions. Mods (Modifications) can be made to Victron Software by the Community. Please use the modifications space for enthusiasts who want to push what is possible, without official Victron Support.
