samatch avatar image
samatch asked
Pheonix Inverter Statistics
Hi there,
I have a Phoenix 24/500 ve.direct inverter. I am using it with the venus firmware on a raspberry pi. I also have a SmartSolar 100/20 and a BMV 712.
In the VRM Portal, the statistics for the inverter are incorrect... It correctly shows the voltage operating at 230v, but the current hovers between 0 and -0.4 amps... they never seem to reach into the positive...
On the venus device, the stats also show 230v, 0 amps, 0 watts... occasionally the watts will flick to 25 or 50w, but only very briefly.
I know I am drawing about 150w through it (according to the BMV-712)
I read a post that was around 9 months old, saying that the stats for inverters over ve.direct was still in development. Is this still the case? It's curious that I get the correct voltage, but not the correct current...
I also seem unable to adjust all the settings for the Phoenix on the Venus interface... for example, adjusting the low voltage shutdown. Is this expected?
Many thanks! :-D
VRMVenus OSPhoenix Inverterremote console
Hi Samatch,
The power reading on the ve.direct inverters is not very accurate. Unfortunately this is the way that it is. There was a previous post about it here. This is a hardware limitation.
For now, adjusting the other parameters (eg low voltage shutdown) from their defaults requires VictronConnect, and a VE.direct to bluetooth adapter, or VE.direct to USB adaptor depending on your device.
The power reading from your BMV should provide a very accurate figure for what is being transacted from the batteries. Though it will not be inclusive of the solar, it is possible to get a good idea of the overall flow of the system if all devices are connected to the GX device.
samatch avatar image samatch commented ·
Hey Guy,
Thanks for responding, much appreciated.
Disappointing that the statistics are not available / accurate. I'm curious as to what the limitation here is? Is it just a question of Victron not having included an appropriate measuring device on the outbound AC or something? Seems a shame for an inverter that I didn't think was at the cheaper end of the market...
At the moment I can see the DC load stats through the GX device (raspberry pi Venus), which also includes the inverter. Ultimately I'm just playing around with this equipment, it was a nice have to have. A shame I can't have it! :-)
- Matthew
