freddy avatar image
freddy asked
Can an EasySolar be parallel with EasySolar / MultiPlus / Phoenix / Quatro
Two EasySolars (5kV / 48V) can be configured in parallel.
But is it possible to configure an EasySolar (5kV / 48V) parallel with an MultiPlus, Phoenix or Quatro (of 5kV / 48V)?
I don't know what kind of firmware / chipset these other models have. But it seems a bit redundant to combine 2 EasySolars (to have 2 times the build in MTTP capacity / 2 times a Color Control).
I need more output then one EasySolar can provide.
MultiPlus Quattro Inverter Chargerbattery chargingPhoenix InverterEasySolar All-in-One
wkirby avatar image
wkirby answered ·
In some circumstances, Yes, the EasySolar basically has a MultiPlus within.
Find out what the first four digits of your EasySolar firmware is and then source a MultiPlus whose firmware contains the same first four digits.
4 comments
freddy avatar image freddy commented ·
Thank you!
bodhirah avatar image bodhirah commented ·
Will Phoenix 24/3000 parallel with Multiplus 24/3000 assuming firmware numbers match in the same way?
Guy Stewart (Victron Community Manager) avatar image Guy Stewart (Victron Community Manager) ♦♦ bodhirah commented ·
They will not match. This configuration is not supported.
andy156 avatar image andy156 commented ·
Can I buy an EasySolar and then a Multiplus of any firmware and update them to be the same?
