buryck avatar image
buryck asked
Multiplus 24/3000/70-50 default low voltage disconnect
Hello, i have a EasySolar 24/3000/70-50 wich basically has a multiplus inside. I use it with a lifepo4 battery. I never run it so low for the inverter to trigger a disconnect, but i'm curious to know what is the default battery low voltage disconnect on the multiplus 24/3000, does anyone know?
Thank you :)
MultiPlus Quattro Inverter ChargerPhoenix InverterEasySolar All-in-Onevoltage
seb71 avatar image
seb71 answered ·
Probably the default is 18.6V, which is much too low for LiFePO4.
Do not leave it like this.
6 comments
buryck avatar image buryck commented ·
Thank you very much for the answer.
Yes, waaay too low. I was afraid of that. So the only way to change this is with a ve.bus to usb cable or with a ve.bus smart dongle?
I'm probably saying something stupid, but i was thinking if maybe i can connect it to the GX color control through the relay input? Also, it's already connected with a rj45 cable, and the GX CC has a smart shunt connected to it. I noticed the voltage that the multiplus detects when is on, is lower than the one given by the smart shunt, but i guess that's normal. Is there a way to have the inverter read the real voltage coming from the shunt, and disconnect based on it's reading of the voltage?
Thank you :)
seb71 avatar image seb71 buryck commented ·
If you have a CCGX with Internet access and a VRM account, you can see and change the Inverter settings using that (and VE Configure 3 software on a Windows PC).
buryck avatar image buryck seb71 commented ·
Thank you, i'll try doing that.
Don't change the grid code (unless you are absolutely sure about the correct option for your case), because you will need a password to change it again.
Regarding the other settings, be careful.
Ok, i won't mess with that, thanks for the advice :)
Also, better read the CCGX manual (and the manuals of all your devices). Especially take a look at DVCC.
