ralphd avatar image
ralphd asked
Multiplus II - prevent low voltage shutdown from momentary surge
I have a Multiplus II on my boat Powered by 5 AGM 12V batteries. If the batteries are at ~70% capacity and I turn on something with a high initial surge such as a coffee maker, I trip the Multiplus‘s low voltage shutdown.
Is there a delay that can be set for the low voltage shutdown? Only a second or two would resolve my issue.
Thank you,
Ralph
Multiplus-IIvoltagelow battery warningshutdown
Paul B avatar image
Paul B answered ·
Time to replace your batteries with Lithium I would think
the batteries yoiu have cant supply the required amps, and this will only get worse.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
