hugo-rojas-espinoza avatar image
hugo-rojas-espinoza asked
What is the range spectrum radio and transmission power for Cerbo in wifi and Bluetooth?
We are having issues in customs because the local regulator has non technical information of the Cerbo and Solar controllers with bluetooth and wifi functionality. As they consider that there isn't information in manual and datasheet they are denying the importation of these parts.
Please could you help us with the following information for the technical person in our Telecom and Transport ministry?
If the module transmits in the radio spectrum with a power equal to or less than 10 milliwatts (mW) on the antenna (effective radiated power), please confirm.
What is the frequency bands in which it operates, in order to determine if the module operates in bands allocated to public services?. (We read 2.4GHz and 13 channels in forum).
Please, do you have this information in a white paper of Victron products?
Regards,
Hugo
cerbo gxMPPT SmartSolarBluetoothwifiVE.Direct Bluetooth Smart Dongle
wkirby avatar image
wkirby answered ·
I'm pretty sure its FN-LINK 6223E-UUD WiFi / Bluetooth combo module:
https://www.signal.com.tr/pdf/cat/6223E-UUD.pdf
Strange that the official should stop a device which is communicating in 2.4GHz ISM band just like millions of laptops, handheld mobile telephones and tablets. They must be really busy inspecting all of those gadgets too!
hugo-rojas-espinoza avatar image hugo-rojas-espinoza commented ·
Thanks for your help. This happens every day and it happens with many products. Sometimes for no reason. The risk in the midst of excessive bureaucracy.
