seafur avatar image
seafur asked
SmartShunt no SOC on Cerbo
I have a SmartShunt connected to 6 lead-acid 6v batteries in a 2s3p config. SmartShunt with updated firmware, installed in April 2022, SmartShunt shows SOC in VictronConnect on iOS via Bluetooth. Added a CerboGX in May 2022 with current firmware. CerboGX does NOT show SOC. When I looked at the network config of the SmartShunt in VictronConnect it shows it is sending voltage and current data but that's all. I assume it needs to show that it's sending SOC or the CerboGX won't be able to display SOC. How do I add SOC to the data the SmartShunt is sending over VE.direct. I also have a Victron SmartSolar MPPT 100|20 connected via VE.direct and I'm getting what I want from it. Since adding the CerboGX I've only discharged to 98% and back up to 100%, I don't think I need a full cycle since I can already see SOC value in VictronConnect app so obviously the SmartShunt has figured out SOC.
cerbo gxSmartShuntSOCVE.Direct
Is the SmartShunt shown in the device list and is it selected as battery monitor in the settings of the Cerbo?
seafur avatar image
seafur answered ·
@Matthias Lange - DE, not sure but I'm see voltage and current as the above screen grab from Cerbo shows so I'm thinking it is but honestly I don't remember making that setting myself. Maybe it's auto... The system is at a remote site I'm going to this weekend but I have really sketchy internet access there. I'll check that and try to update this thread.
Any other thoughts before I head up the mountain?
seafur avatar image
seafur answered ·
@Matthias Lange - DE Thanks for the pointer. I assumed my SmartShunt was connected since I saw battery voltage and current, turns out the MPPT 100|20 was providing battery voltage and current. My SmartShunt was found by the CerboGX because I pulled the connector slightly out while installing other items. Once I got the cable connected properly I looked at the CerboGX and it saw the SmartShunt and I started getting the SOC disply.
