Michael Scholze avatar image
Michael Scholze asked
How to set the battery voltage where PV Inverter Support Assistant starts rising frequency
I'm using a Multiplus II offgrid setup with cerbo gx and pylontech batteries and want to add a Fronius Symo to AC-OUT 1. Pylontech has a absorbtion at 51V and float at 52V. According documentation of the assistant (https://www.victronenergy.com/live/assistants:pv-inverter-support) the assistant will start rising frequency at 54V. With this configuration it will never rise frequency for Pylontech batteries.
How can I reduce the voltage at which the PV Inverter Support Assistant will increase the frequency appropriately for Pylontech batteries as well?
Is it possible to configure via DVCC?
Multiplus-IIPylontechAC PV CouplingAssistants
Rob Duthie avatar image
Rob Duthie answered ·
Yes it is
Regards
Rob D
NZ
